496HO Down on power >
496HO Down on power
496HO Down on power
Old 08-20-2022 | 02:49 AM
  #261
Veteran: Army
Congrats on getting her dialed in with plenty of summer left!
DrFeelgood is offline
Old 08-20-2022 | 09:11 AM
  #262
Guys,
I am still only seeing about 52lbs of fuel pressure in boost condition. ProCharger manual indicates we should be at 62-65lbs. Assuming the pump is capable, the regulator is functioning properly and the gage is accurate, I should adjust the regulator to achieve that pressure?
I’ve also noticed that when I initially turn the key, when the fuel pump primes the system, the gage initially show that ~52lbs, then drops to the manifold vacuum condition pressure or 38lbs. Is that initial 52lb reading showing me the boost condition pressure? Or do I need to make an adjustment, make a hard run, make an adjustment, make a hard run, make an adjustment….. etc…. Until the boost fuel pressure is where we want it?
Thanks. Brad.
(937)545-8991
Brad Christy is offline
Old 08-20-2022 | 09:45 AM
  #263
how much boost are you making?
sutphen 30 is offline
Old 08-20-2022 | 10:27 AM
  #264
Sutphen,
~3lbs @ 5K RPM.
Thanks. Brad.
(937)545-8991
Old 08-20-2022 | 07:32 PM
  #265
Sutphen,
~3lbs @ 5K RPM.
Thanks. Brad.
(937)545-8991
with the way you have it set up,52psi is probably about right for your boost,as set up now.how are your afr's?
Old 08-20-2022 | 08:45 PM
  #266
Sutphen,
AFRs….. Now you’re talkin’ Egyptian….
I do know what AFR is. I just don’t know how to get that data. I now have a Techmate Pro, if that helps.
Thanks. Brad.
(937)545-8991
Old 08-20-2022 | 09:31 PM
  #267
air fuel ratio,,techmate doesn't do it
Old 08-21-2022 | 03:10 AM
  #268
Veteran: Army
Need to add O2 sensors if you want to see AFR.
Old 08-21-2022 | 12:59 PM
  #269
DrFeelgood,
Where do I add them where they won’t get eaten by the water in the exhaust? I have the stock Merc 496 manifolds.
Thanks. Brad.
(937)545-8991
Old 08-21-2022 | 01:41 PM
  #270
Veteran: Army
DrFeelgood,
Thanks. Brad.
(937)545-8991
They have to be added in a location prior to where water mixes with the exhaust gas. Something like this, for example:
https://affordable-fuel-injection.co...adapter-plate/
