Wide band o2 sensor location
Ryan the auto meter does use Bosch 049 sensor.
That seems really close to the tip, you check if theyre getting wet ?
I had some reversion at idle so I used to do the opposite, wait till I was on plane and running, making sure the 0`s were nice and dry and then turn them on.
Whats makes you think turning them on early and shutting them off late would help with lifespan? I wouldn`t run them at idle
2 things kill 02s , heat and water . You might also be reverting air since the tails are so short
https://www.ebay.com/itm/353868551416
My AEM info for my bosch 4.9 sensors says to never run engine with no power to 02 sensor. Always allow 02 sensor to heat up before starting engine for optimal sensor life.
