What do I need???? >
What do I need????
What do I need????
Old 09-04-2022 | 08:49 AM
Originally Posted by getrdunn
Yes correct - I can’t bend it no where near enough…. Like I’m only getting about an 1/8 throttle. That just dawned on me regarding the style of plate under carb type. I actually have some here but for 4150 platform. Just strange the engines that were in had 1050 Dom’s. Regardless what I’ll have to get Tks
Dremel or a hacksaw would've made clearance with little effort.
Smitty275 is offline
Old 09-04-2022 | 09:53 AM
TomZ's Avatar
Originally Posted by chris302
On transmission for trs boat you will have a temp. Alarm switch and neutral safety switch. Don't remember colors
Light Blue should oil pressure.
Tan with Blue stripe is alarm.
Brown with White stripe (may look black) should be oil temp (Merc harness - trim indicator wire).
Yellow and Red stripe is neutral safety (it breaks the connection to the solenoid).
My TRS boat is wired this way.
TomZ is offline
Old 09-05-2022 | 09:22 AM
Notta… The accelerator pump arm was literally laying flush under the throttle cable bracket. Allowing no action whatsoever.
If I would’ve had a pic of underside it would’ve clearly showed.
getrdunn is offline
Old 09-06-2022 | 12:35 AM
mcollinstn's Avatar
I am having a hard time figuring out whats happening. A "throttle plate" is the round things with 2 screws on them that open and close the venturis - so I'm guessing that you are talking about the cable mount brackets?
mcollinstn is offline
Old 09-06-2022 | 10:59 AM
correct the accelerator pump arm is flush up against the bottom of bracket. I just ordered the other brackets.
getrdunn is offline
Old 09-06-2022 | 04:53 PM
TomZ's Avatar
Can you go with longer studs on the throttle side, fasted the carburetor with nuts/washers under the throttle bracket, the fit the bracket and fasten within another nut and washer?
TomZ is offline
Old 09-06-2022 | 04:54 PM
TomZ's Avatar
Never mind. That won't work either. Your idle screw is in the way.
TomZ is offline
