Chevy 5.3 LS injectors >
Old 09-13-2022 | 11:22 AM
F-2 Speedy's Avatar
Default Chevy 5.3 LS injectors
Does anyone one make an injector for a 2000 chevy truck 5.3 LS with the EV1 connector
TIA
Speedy
F-2 Speedy is offline
Old 09-13-2022 | 12:06 PM
I've used LS1 length injectors many times with a simple fuel rail spacer.
Another option that I've personally used is short LS3 injectors with an injector spacer.
Menage_Aqua is offline
Old 09-13-2022 | 12:22 PM
F-2 Speedy's Avatar
Could you post a link or pic to see, my new harness has ev1 connectors and I dont want to use an adapter, first LS for me so Im learning
thanks
Old 09-13-2022 | 12:42 PM
F-2 Speedy's Avatar
this and a LS 3 injector ?
https://www.michiganmotorsports.com/...-a-ls1-intake/
Old 09-13-2022 | 01:22 PM
articfriends's Avatar
A LS3 injector will have a EV-6 connector, not a mini timer/ev-1 so wont solve your dillema completely so uoud need: ls-3 injectors (uscar/ev-6 connector), spacers then adapters for your harness, at least they DO sell a wireless adapter though.spacing the rail up and using ls-1 injectors with ev-1 connectors or really ANY "normal" full size injector with ev-1 connector as the are same length as ls-1 would open up your options, Smitty
articfriends is offline
Old 09-13-2022 | 05:04 PM
Yea sorry, Artic is correct, I meant any shorter injector (like an LS3 height) that has the correct EV1 plug if you can find any.
The injector spacers seem kinda hokey, but they've not been a problem with the Bosch 210s on my 940 rwhp turbo deal.
If you're leaving it N/A, and you're using a stock truck intake, the fastest, cheapest, and easiest route is to buy a set of LS1/LS6 EV1 injectors and space the fuel rail up with spacers and longer bolts. Here's a kit from summit.
https://www.summitracing.com/parts/i...RoCc-AQAvD_BwE
Also, here is a good resource regarding LSx injector lengths and connectors.
https://www.ictbillet.com/swap-guide...wap-guide.html
Old 09-13-2022 | 05:22 PM
F-2 Speedy's Avatar
Im going with the LS1 injectors and spacing the rail up, thanks for the input....
Old 09-21-2022 | 10:09 AM
F-2 Speedy's Avatar
found this chart if it helps someone out
