Oil temp/cooler setup questions
I will try to look him up thanks!
Another option, back to the oil pan, I have several buddies that are welders by trade...would it serve the same purpose if I modified my current pan to a tee style bottom like the ones they sell instead of buying one? Could just add onto my current pan and add a little on the pickup tube and have my extra capacity unless there is some kind of magic inside of those things I'm not aware of??
13 Plate Remote Cooler Assembly - Hardin Marine (hardin-marine.com)
Hardin Marine - HP Engine Oil Cooler 3" Diameter, 25" Overall Length, 1" NPT Connection (hardin-marine.com)
Looking at these two options for a cooler. I can't mount either above the bell housing due to interference with my exhaust so I will have to make some mounts or figure out a way to mount them elsewhere....what's everyones thoughts on these 2 options? Square or Round basically hahaha
I went with the smaller square. Easier to mount from a real estate perspective and you can change the internal element if needed. Very easy to plumb.
I don't make near your HP so smaller works great for my application.
