Valve Spring removal tool for HP500 Carb?
Need to buy a valve spring tool to change my springs with the heads on the block. I see many options, Comp Cams & LSM have two very different styles. The LSM is a lot more expensive.
I probably will only use it once.
Would appreciate some input and suggestions on which ones to consider.
Thanks!
Thanks!
Not sure what the two you mentioned look like but I have one of these :
https://www.moroso.com/stud-mount-va...mpressor62370/
There are several version of them from different manufacturers and I think they all probably work ok. For a one time only use maybe a local engine builder will let you borrow one ? I loan mine out a few times a year
The ones that I have seen that look like it will make the job the easiest (you can work with both hands without holding the big leverage arm on the other style), are these Comp Cam bolt-down ones. It allows to slowly remove and reinstall, heard the many horror stories of the keepers going flying (or worse into the engine)
https://www.summitracing.com/parts/cca-5462
Here are the specs I found for HP500 head part #714-938-8M0115143 (handy sheet, lots of details about the head)
http://www.quicksilver-products.com/.../8M0115143.pdf
COMP Cams Valve Spring Compressor Tools 5462 "They can be used on all GM Gen III/IV LS-type engines"
And the other one is: https://www.summitracing.com/parts/cca-5337COMP Cams Valve Spring Compressor Tools 5337 "They can be used on all GM Gen III/IV LS-type engines"
They are specific for type of engine and head. Are the 500 heads a LS head? I have a sheet that has the full details on it, but not sure if this head is the same as a normal LS head?Here are the specs I found for HP500 head part #714-938-8M0115143 (handy sheet, lots of details about the head)
