PSI 8.8 liter / 550ci ???
#31
Thanks a million for the info !!!
#32
I asked the seller and he is as clueless as I am.
#36
Seller did confirm that he has two of the 80000795R longblocks available... so I just purchased both @ $1500ea + $225 shipping.
Hopefully I can build one good one out of the pair... assuming they have good parts inside them and have the better LS style heads.
#37
If I can get away with using these LS heads and intake instead of buying the aluminum Raylar heads... that will save a bunch of money also.
I'm not looking to spin this thing to 7k... I think 5500-5600 is plenty. I can prop the boat accordingly so I dont need to spin it any faster.
Maybe a fresh rebuild with the right camshaft will work... AND save some money.
#39
I cant speak to the valve sizes or flow numbers but would really like to know also.
If they are significantly better than the 8.1 cathedral port heads, I will give them a try.
I might get away with just dropping a bigger camshaft in a fresh PSI longblock if these heads are a viable option.
