Converting raw water pump >
Old 06-24-2023 | 06:00 AM
Default Converting raw water pump
I want to eliminate the raw water pump mounted fuel pump and go to electric fuel pump, and change the water pump to one without the fuel pump mount. Does the water pump #46-807151A12 require a different bracket or belt tensioner?
jeffer is offline
Old 06-25-2023 | 11:46 AM
There's a plate kit available to cover and seal the top opening for the fuel pump as well.
Tractionless is offline
Old 07-09-2023 | 08:30 AM
I got the solution to all my questions from Dennis Moore @ Moore Performance Marine. What a great and knowledgeable man. The kind of customer service that is rarely experienced today. He not only solved my problem but restored my faith in American manufacturing. Thank you Dennis!
jeffer is offline
Old 07-09-2023 | 08:44 AM
SB
Cool. :Thumbs.
And the solution was (insert drumroll) ….
SB is offline
Old 07-09-2023 | 11:11 AM
He builds the water pump intermediate housing from billet aluminum and makes his own V belt pulley (which is no longer available from Merc.),uses the Merc pump housing, and it all mounts to my original Merc. bracket with the rack and gear tensioner. All lines up perfectly. I then installed an electric fuel pump.
jeffer is offline
Old 07-09-2023 | 11:32 AM
jeffer is offline
Old 07-09-2023 | 01:32 PM
SB
Okay, found it.
:thumbs
IndexofallParts
SB is offline
Old 07-09-2023 | 07:42 PM
Active Streak: 30 Days
Looks like he has the correct Carter fuel pump. 130.00, 60% less than the Merc replacement.
Helmwurst is offline
Old 07-09-2023 | 08:39 PM
Rookie's Avatar
Or you could just buy an $8 block of plate. I've been using them for 20 yrs.
https://www.summitracing.com/parts/sum-402035
Rookie is offline
Old 07-10-2023 | 08:26 AM
Anyone interested in posting pictures of their electric fuel pump conversion/installation? I am considering that option for a Winter project.
