Thermostat replacement >
Old 12-01-2002 | 11:51 AM
Ric232
Default Thermostat replacement
Okay, here's an easy one. I'm thinking of replacing the thermostat on my 454 Mag MPI since it is original (over 4 yrs old). Any suggestions on what part I should use? Stock MerCruiser? Somebody else's product?
Dustin Whipple already suggested that I drill 4 to 6 3/16" holes in the stat to allow the engine to run a little cooler.
Thanks,
Old 12-01-2002 | 06:46 PM
Six Leg Dog
I would only use Merc parts and don't drill any holes!! The ECM needs the right one with no holes.
Old 12-02-2002 | 07:27 PM
Ric232
Stock 454 Mag MPI. Dustin recommended drilling the holes to allow the engine to run slightly cooler and generate a little more power. It was not in response to my engine overheating or anything like that.
Old 12-02-2002 | 08:27 PM
If it ain't broke, don't fix it.
Drilling a few holes in a t-stat isn't going to give you any more power.
Griff is offline
Old 12-03-2002 | 06:33 PM
Ric232
If I had heard the tip from anyone except Dustin (or Dennis), I would be skeptical. Hard to question those guys.
Old 12-03-2002 | 07:30 PM
BajaBennett's Avatar
I would suggest that you use only the thermastat that MerCruiser calls for. Since you have a fuel injected engine the computer adjust the fuel mixture based on the temp. If you run the engine below spec. you engine will run rich.
Dail
BajaBennett is offline
Brandon
3
10-29-2007 12:01 PM
nocigarette
4
06-19-2006 09:53 PM
boatnt
2
02-13-2006 06:55 AM
Perfectmix
9
05-06-2004 08:32 PM
stevel
2
05-20-2003 04:37 PM
