Thermostat Replacement >
Old 05-20-2003 | 12:12 PM
Default Thermostat Replacement
I have a 1991 Mercruiser 502 Magnum Carb. Stock. One engine is running a little cooler than the other . This has been verified by a IR thermometer at thermostat housing. I think one of the thermostats is stuck open or partially open. I pulled the top cover off of the housing and tried to remove the themostat. There is a brass sleeve on top of the thermostat that appears to be stuck in place. I don't think it has been replaced in many years. Any hints on how to get the sleeve out (the thermostat is underneath it). If not, I will just yank it out, bending it and buy a new one.
Thanks!
Steve
stevel is offline
Old 05-20-2003 | 04:15 PM
I just yanked mine out its only a buck or two for a new one and they come with a new gasket for the bottom
THRILLSEEKER is offline
Old 05-20-2003 | 04:37 PM
bobby daniels
a few degrees won't hurt ,, just yank it if you want to ,its the only way out
Brandon
3
10-29-2007 12:01 PM
nocigarette
4
06-19-2006 09:53 PM
boatnt
2
02-13-2006 06:55 AM
Perfectmix
9
05-06-2004 08:32 PM
Ric232
5
12-03-2002 07:30 PM
