Carb to EFI
Old 08-17-2023 | 08:37 AM
  #31
Someone knows the size of these TB merc 565 is using ?
Not sure of the size, but it is the same part # used on all the QC motors and some OB's.
techman is offline
Old 08-17-2023 | 09:12 AM
  #32
From what I have read I believe they are 80mm throttle bodies.
Nosfool is offline
Old 08-17-2023 | 09:51 AM
  #33
It’s written made in Germany probably bosch .
Bulitz is offline
Old 08-21-2023 | 04:43 PM
  #34
Originally Posted by articfriends
yes, it will take work to get the volute to fit over it, I cut one down w die grinder to get it to fit, the most recent one rookie posted pics of we used mill and rotary table to cut lip down and bored the volute
This is the setup that I am running with Holley hp efi and dual sync distributor and smart coils like the 700sci use.
Nosfool is offline
Old 08-21-2023 | 07:59 PM
  #35
Rookie's Avatar
What thermostat housing are you using?
Rookie is offline
Old 08-22-2023 | 05:22 AM
  #36
articfriends's Avatar
I was wondering that myself, looks like one for a jet boat
articfriends is offline
Old 08-22-2023 | 06:27 AM
  #37
Just divided water outlet from Hardin
Nosfool is offline
Old 08-22-2023 | 07:09 AM
  #38
https://www.enginelabs.com/news/test...s-on-the-dyno/
I think TB on the surface of plenum is better . Saw this article this morning
Bulitz1 is offline
Old 09-01-2023 | 05:27 PM
  #39
I have the customers 548 on the dyno, ordered this to try to gain tstat hsg clearance , the air horns already hitting the only dyno tstat housing I could get to fit at all. Gonna run it with it and without it of course and see what it does to the hp. Carb to EFI-hly-717-15_xl.jpg
Old 09-01-2023 | 06:17 PM
  #40
That may be the ticket there to get the clearance for the volute
Nosfool is offline
