HP estimates on a 598 I'm having built ? >
Old 08-31-2023 | 08:59 AM
Originally Posted by cdaniel525
Curious on what you guys think I may come up with on a 598 I'm having built... I'm replacing a 632 (10:1 comp) with AFR CNC 335 heads, hydraulic cam: 262/270 --- .720/.720 lift --- 112 LSA, Edelbrock Super Victor intake, and 1050 dominator, but had some oiling issues... And a few builders and enthusiasts said those heads and cam were a bit small for the 632. And I'm going to do the 598 to avoid the 632 oiling issues. With that said I am hoping to get back to the same power / speed I was previously at.
Here's my spec'd build so far:
Dart Big M 10.2 block
598 rotating assy
10:1 comp. ratio
Brodix Xtra-O 351cc Flow #s -
VALVE SIZE 0.200 0.300 0.400 0.500 0.600 0.700 0.800 0.900
2.350 INTAKE 50° 154 226 300 356 405 433 441 444
1.880 EXHAUST45° 134 177 216 249 277 304 308 313
Brodix oval intake CNC port matched to the heads
Solid lifter, custom grind cam; 272/280 @ .050 --- .756/.756 lift --- 114 LSA
Comp ultra pro magnum XD rockers
Dominator 1050
Short block is already built, cam is in, and heads are on order. Would love to hear everyone's thoughts on what I may make for power and/or any suggestions / comments....
Thanks in advance!
Crank aerating the oil and losing pressure? Is that why you reduced stroke?
hogie roll is offline
Old 08-31-2023 | 09:03 AM
Active Streak: 30 Days
598 rotating assy
10:1 comp. ratio
Dominator 1050
Thanks in advance!
Have it dynoed and broken in on the dyno.
Helmwurst is offline
Old 08-31-2023 | 10:28 AM
Originally Posted by KAAMA
Sounds like a very interesting project---I actually like the idea of your current AFR 335cc cnc ported heads for a 632cid engine for marine use at about 5800rpm and below, but I am curious to know what kind of horsepower numbers you were getting with that 632cid engine with those 335cc AFR heads?---and what the top/peak RPM with the peak HP with the 335cc heads and the cam you were using???
Also, what kinds of "oiling issues" were you experiencing with your 632" engine?---Is it that problematic that you have to reduce your CID to a 598" ??? Are you planning on using the same block from the 632" for the 598" ???
I am very interested in the idea of a 632" for a marine application. Thanks
The 632 came in the boat when I bought it and ran really good and strong for 2.5 years for me so I really can't complain.... BUT as I got more and more seat time in the boat and doing poker runs actually running it higher RPM for longer periods of time till it grenaded, block destroyed and all. When I tore it down to see whats salvageable almost every bearing was burned up and rods had evidence of overheating. 99.9% sure the one bearing spun and snapped the rod, cracked the cylinder wall, and block pan rail, etc. The bigger crank of 632 aerates the oil and even though you may not see a drop in oil pressure, the aerated oil just doens't lubricate properly, esp at high RPMs... This is just a quick summary of things I've read, spoken with a few enthusiasts, and confirmed by at least 3 engine builders when I discussed what to replace this motor with. That said, if you went dry sump system the 632 or bigger would be great, but I'm just not willing to risk it from what I saw inside my engine once torn down. It was a bad ass motor tho while it lasted! That said, I never had the dyno sheet but did talk to the engine builder before I bought the boat and he said it made 850hp, but when I talked to all these other engine builders and I asked what the combo would make with the heads and cam combo, none said it'd make anywhere near the 850 he claimed. Bottom line I have gotten from the engine builders and enthusiasts so far is the flow #s of the AFR and old cam just don't support 850hp. Others I have talked to mentioned either very generous dynos or correction factors turned up to meet a customers goal #. When I used Desktop Dyno with all the specs, it shows this new 598 being stronger as well. FINGERS CROSSED
Originally Posted by articfriends
On dyno with dry headers will make about 820 hp at 6000/6200 and about 760 to 780 tq at about 5000. Your Etops and carb are both too small and will be determinig factor of what it actually makes in the boat. The 1 7/8 primary in your headers will be a choke point with the cu inches/cam/heads you have but we all have to work with some of the parts we already own on these boat builds, Smitty
Solid points Smitty... It's the current headers I have so hopefully shouldn't hurt me anymore than I was before with the 632 since I am hoping to just get back to about where I was before or a touch more. I can always upgrade them as they get older but thats a big expense I don't want to take on just yet. Maybe even the Stainless Marine Gen 3?
But I can easily upgrade the carbuerator or have Nickerson rework it for this motor. I actually should take a look an see what CFM the dominator is... Nickerson built it for the 632 before I bought the boat, so it may be bigger than I am assuming.
Precisely why... I never really saw a drop in oil pressure, but every bearing was all burned up and evidence on the rods of overheating as well.
That's the plan... Might not be complete till later in the Fall, just excited and curious to see what others think it may make for power and if any suggestions/concerns to address before its fuly built so I can tackle them now.
cdaniel525 is offline
Old 08-31-2023 | 07:36 PM
GPM
Damn sounds somewhat similar of a build 👍. I'm also 114 LSA, but just a bit smaller on cam specs. I'm running CMI Etop headers, tails dry to the tip outside the transom.
And that max 6200 RPM sounds perfect. Do you mind sharing what your HP/TQ was? And some more details, such as which Brodix heads, what intake, compassion ratio, etc etc
thanks
I ran the BB2 Xtra CNC ported, Dart tunnel ram converted to EFI, 2 , 1200cfm throttle bodies, 2.375 primaries 4.5 collectors. I never dynoed it without the Procharger. A similar 583 that I built with the same heads, cam and intake made 778 hp and 742 torque. With a small shot of NOS it made 1027 hp and 998 torque. I ran 9:1 compression in both motors. I personally wouldn't use anything shorter than a 6.7 rod with a 4.5 crank.
GPM is offline
Old 08-31-2023 | 07:45 PM
GPM
We did FLOW test the E tops, 2 runners on both sides flowed 296 CFM the other 2 were 248 CFM, not good for HP.
GPM is offline
Old 09-01-2023 | 05:22 AM
articfriends's Avatar
So on my Sim you show about 800 hp/760 tq w your 1 7/8 headers, short runners plus 1050 carb, if header size is theoretically changed to 2 1/4 with longer runners and 1250 carb, shows closer to 840. Keep in mind Sim numbers IF you do the manifold and exhaust efficiency correctly are a "best case" scenario, I have only beaten the Sim in best state of tune on my dyno a couple of times.
articfriends is offline
Old 09-01-2023 | 06:31 AM
What oil pan do you have?
Old 09-01-2023 | 06:44 AM
Thanks articfriends.... Does it show what RPM that 800/760 is at? Also, any chance you can you run the Sim with my old 632 just for comparison?
Old 09-01-2023 | 07:01 AM
The old pan was a KE/Hardin XS Offshore pan. Never saw any evidence of windage on the guage, but I wouldn't use this one again as its a steel pan and was rusting from the outside in. Was finding pieces of flaked metal in the bilge but had no idea where it was coming from, and when I pulled the motor it was almost paper thin in some areas.
New pan going in is a Moroso 20385... All aluminum, with billet end main bearing surfaces, trick windage tray, double kick outs, etc. Came recommended from the engine builder and another buddy runs it in his 29 Kryptonite with good luck. Apparently its the builders go to pan for motors with windage issues or to simply avoid in the first place, and he said he's never seen a motor have any with this pan so we shall see.
Old 09-01-2023 | 09:37 AM
same heads off your 632, cam specs?
your current combo on my sim tq peaks at 5000/ hp peaks at 5900 to 6000
