HP estimates on a 598 I'm having built ? >
Old 09-07-2023 | 05:53 AM
  #31
articfriends's Avatar
Originally Posted by ICDEDPPL
Boosted: Given number of lbs/hr / 0.60 BSFC = HP (for gas)
1023HP seems more accurate .
Whats your wot target afr currently/
articfriends is offline
Old 09-07-2023 | 10:31 AM
  #32
Still building my fuel map but that was around 12AFR
need a half a point lower when Im done.
ICDEDPPL is offline
Old 09-07-2023 | 11:07 AM
  #33
so your seeing 12.0 at wot in hard boost ?
Old 09-07-2023 | 07:02 PM
  #34
GPM
Just a thought, some of your BSFC could be the HP it takes to spin the Blower, which would increase as you turn up the boost.
GPM is offline
Old 09-08-2023 | 11:51 AM
  #35
7lbs of boost yes.
I like lower 11`s myself but you ever see a 1075 on the dyno... 12.4afrs up top
Also my buddy been runing this map with low timing on a 43 Nortech with 5.0l Whipple without issues .. that would scare the crap out of me but it works for him and he does not drive it easy.
ICDEDPPL is offline
Old 09-08-2023 | 06:11 PM
  #36
GPM
To much fuel just washes cylinders,
GPM is offline
Old 01-09-2024 | 08:24 AM
  #37
Preliminary results are in........
843/755 with shop carb and no vacuum pump
836 with my older style Dominator and no vacuum pump
849 with my older style Dominator and WITH a vacuum pump
They have a Gen 3 Marine Ultra Dominator being thrown on today to see how that'll do as its supposedly better than their shop carb... Hoping this might push 850 w/o the VP. Tho, I am likely to get a VP since of the added oiling benefits (no leaks, reduce crankcase pressure) besides just the HP.
Im stoked with the #s I've gotten so far tho! Right above the area I wanted and was thinking she'd land!
Below is a pic of my older Dominator, am I correct in assuming a Gen 3 would be a big improvement with the radiused edges for flow and another other improvements they made?
cdaniel525 is offline
Old 01-09-2024 | 01:59 PM
  #38
Dyno headers I assume? What was your correction factor?
hogie roll is offline
Old 01-10-2024 | 12:06 AM
  #39
It's really hard to make that kind of N/A marine power.
Even harder to make it reliable for 100-200hrs in offshore poker run conditions.
Almost impossible to make the boat run comparable to similar forced induction power.
Especially with a build on this budget.
Still badass and I hope you have fun, and guess the time to freshen them before they break. Thanks for sharing.
offshorexcursion is offline
Old 01-10-2024 | 05:19 AM
  #40
bencini231's Avatar
Was this full acessories and dry dyno headers or wet headers? Also ask previously asked, what was the correction factor?
bencini231 is offline
