2001 VOLVO DPX500 Flywheel / Starter >
Old 03-04-2024 | 08:37 PM
Default 2001 VOLVO DPX500 Flywheel / Starter
Does anyone know the number of teeth on the flywheel for the 2001 VOLVO DPX500 8.2L. I am wanting to replace the starter with a High torque starter since mine is dragging and barely cranks. it has been that way since new ( I only have 89 hrs on the engines).
Mickeyfun is offline
Old 03-05-2024 | 03:29 AM
Ayuh,....... Pull the starter, 'n look at the bolt pattern,......
Straight across is a 12" flywheel, 153 tooth,.....
The staggered pattern is the 14", 168 tooth,....
Bondo is offline
Old 03-05-2024 | 08:06 PM
Thanks a million, I have The staggered pattern starter Now I need to go find a starter.
Old 03-06-2024 | 06:14 AM
Before you waste money on a starter make certain that all of the power and ground cables are clean and secure.
BillK is offline
Old 03-06-2024 | 07:46 AM
Ayuh,..... My advice is to go with a pmm style starter,..... 1/2 the weight, 'n twice the power of the ole style starters,....
Bondo is offline
Old 03-06-2024 | 11:52 AM
I already done that, New 800 CCA battery tested, and clean connections Positives and Negatives on battery side and engine side, also timing has been moved a few degrees retarded and advanced.
Old 03-06-2024 | 12:04 PM
What is "PMM" ? I looked for a Marine Mini starter with gear reduction but could not find one under $400.00 , I like the PowerMaster brand but they don't have Marine Starters,, I ordered ARCO Part #30470-ANEW OEM Quality Hi Torque, Permanent Magnet, Gear Reduction Starter. 1.7 KW for a couple hundreds and hopefully it will work otherwise I will have to step up the expense.
Old 03-07-2024 | 04:55 AM
Ayuh,.... Permanent Magnet Motor,....
Bondo is offline
Old 03-08-2024 | 11:43 PM
Old 03-08-2024 | 11:50 PM
Installed the new starter motor and to my surprise, cranked pretty good. but no start and after a bit of diagnostic found deffective Hi flow fuel pump. just ordered one.
