BBC 509cid tunnel ram efi build. >
Old 07-21-2025 | 10:44 PM
  #121
thanks
madmax2 is offline
Old 07-22-2025 | 09:36 AM
  #122
Not sure why the map isn`t more progressive. 32* anything after 3000 defeats the whole purpose of a map
I don`t have experience with NA but 32* at peak tq would be way too high for what I do.
ICDEDPPL is offline
Old 07-22-2025 | 11:32 AM
  #123
Timing isn't so much about a number vs achieving the aim of combustion with a margin of safety.
As an example in the early days of Hemi NHRA racing, they didn't understand that the massive hemi chamber need ridiculous time to burn. The guy that discovered it was winning...with something like 45° ign timing, until the secret got out.
Different chambers/piston crowns need different timing. Add in the varying exh valve temps and fuel atomization.
Dan's applications see very high air density resulting in high dynamic compression ratios. The extra cyl pressure increases flame front travel speed = less timing required + a safety margin.
Tartilla is offline
Old 07-22-2025 | 06:12 PM
  #124
Originally Posted by JaniH
Sae j1349 corrected power. 32dg timing. There is still vacum at max rpm, maybe the flame arrestors are restricting the air flow. 2 1000cfm throttle bodies wide open
NM and HP on the same page is giving me a headache.
Cole2534 is offline
Old 07-23-2025 | 03:53 PM
  #125
I ask without knowing... I find it curious to see MAP +5.8 psi in a normally aspirated engine. Is that good or bad?
madmax2 is offline
Old 07-23-2025 | 05:24 PM
  #126
MadMax2,
I think you misunderstood Dan's comment. The table is most likely from his engine builds, which were Whippled 555s.
Thanks. Brad.
Brad Christy is offline
Old 02-11-2026 | 08:14 AM
  #127
Going to upgrade My exhaust from stainless marine manifolds to a CMI headers, 1.7/8" primary id/ full lenght primary tubes. I am building custom taill pipes and The question IS what Would Be The desired Id For The taill pipes? I am thinking 3.5" or larger, i could trade few mph at top For better low rpm efficiency. Dyno sheet IS on this thread.
JaniH is offline
Old 02-12-2026 | 02:15 PM
  #128
Jani, are these dry or wet flow?
Make a difference for sure.
You need 2.2cfm/hp for unrestricted exhaust flow.
115cfm/ sq in of exh area.
A 3" tube with 7.07" area = 813cfm before restriction.
813÷2.2= 370hp x2= 740hp Dry exh
Important to note... a bit of exh restriction does not shut everything down..it's an exponential graph.
3.25" would be 867hp.
Tartilla is offline
Old 02-13-2026 | 07:09 AM
  #129
Dry to transom with 4.5" downturns. Not sure how and where exactly to enter The Water. I Would really like to hear some opinnions how to do IT. Also The collector on those cmis IS stupid large, almost 4", i Would really like to replace IT with merge/reverse Coney collector.
JaniH is offline
Old 02-13-2026 | 07:12 AM
  #130
Here IS link For different collector shapes.
https://burnsstainless.com/blogs/art...iB7hvfWslzUW2k
JaniH is offline
