BBC 509cid tunnel ram efi build.
#101
This project seems to be never ending battle. The oil pan kickout is so wide that there is no chance to make the merc raw water pump to fit. I knew i need some kind of mine starter motor, but i tought the pump would fitt. Wonder how the johnsson F6B-9 crank mount pump would work?
#103
Engine is running, 2 weeks to dyno test. First pulls with big tube headers and 10 lambda, then with wet stainless marine manifolds. Are you guys using Sealant with the sm riser gaskets? What sparkplugs i should use? I have ngk bkr6e now installed.
#110
