BBC 509cid tunnel ram efi build.
#71
Should i use this type of seals on exhaust and intake?
https://www.summitracing.com/parts/cca-517-16
#74
Found these runner extensions for weiand tunnel ram. 2" and 4" available.
https://www.ebay.com/itm/23550828552...4AAOSw2GlXKNCR
#75
Only thing we could figure was that the spacer really screwed up the air/fuel distribution.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
#76
Back in the early 80's I had a pair of engines built by a big name guy near Detroit. Had those same intakes. Made good power but in order to lower the RPM band and increase torque he made some spacers like that. Worked great on the dyno. However first run out on the lake it broke one balancer clean off. On disassembly found the other one seconds away from the same fate.
#77
#80
Heads are ready. ferrea 6000, int 30dg backcuts, new seats, bowl/short turn blend, good port had too high air speed @.600 and up, trimming the head bolt pump fixed the problem. 1=good port, 2=bad port, 3=exhaust no pipe, 4.5" bore adapter.
