BBC 509cid tunnel ram efi build.
#81
With milodon pan i cannot use the gm original main bolts, so i bought arp 135-5201 main bolts and found out that the arp bolts are 0.150" shorter compared to gm bolts, I quess this is not a problem? Arp only lists this kit for gen IV/gen V.
#82
The 0.400" loft is pretty good. Exhaust doesn't choke off at higher lift/flow. They should make some good power. What seats did you end up using?
#83
Have to to ask about the seat angles. Quess that the 650-675hp might be possible. Now i try to decide what icl i instal the cam.
#84
#87
Conventional wisdom holds that 1-1/2 X thread diameter will achieve maximum thread strength. Personally, I like as much as I can get, and have designed parts with 2-1/2 to 3 X thread diameter, just to make myself feel better about them. I haven't the foggiest on head bolts, but I'd think you'd want considerably more thread engagement than single thread diameter.
Thanks. Brad.
