525 heads
Old 05-14-2025 | 08:41 PM
tripps's Avatar
Default 525 heads
I know the bolt pattern on ex side is different ,I want to use cmis that I have,anybody drill and tap t hem out ??? How deep did u go ??? TIA
tripps is offline
Old 05-16-2025 | 12:47 PM
Bill 3's Avatar
Why not drill the CMI's to match the bolt pattern?
Bill 3 is offline
Old 05-16-2025 | 03:11 PM
F-2 Speedy's Avatar
Ive done what Bill 3 is saying, but that stainless flange is tough stuff
F-2 Speedy is offline
Old 05-16-2025 | 09:44 PM
tripps's Avatar
Default Heads
Aluminum is alot easier I only have one set of heads most I have are iron
tripps is offline
Old 05-18-2025 | 07:17 AM
I have done it and it worked but getting the bolts in kinda sucked. Wasn’t a quick way of clamping to my mill so I used a mag drill. Worked really good.
larose481 is offline
Old 05-18-2025 | 07:27 AM
These started as 525's that I drilled a standard pattern in so they can be used on either head on the dyno. Either way, yes it can be done and not a tough job.
Old 05-18-2025 | 10:02 AM
F2,
Pro tips...
A cobalt split point drill makes it much easier. They are only minimally more expensive than a standard HSS drill. A good cutting oil also helps a lot. Run the spindle considerably slower than you'd think you should.
Thanks. Brad.
Brad Christy is offline
Old 05-18-2025 | 08:35 PM
tripps's Avatar
Default Heads
Thanks guys mag drill good idea
tripps is offline
Old 05-18-2025 | 10:43 PM
articfriends's Avatar
those headers look so familar, good job buddie!
articfriends is offline
