-   -   General Pushrod/Rocker Theory (https://www.offshoreonly.com/forums/general-q/386925-general-pushrod-rocker-theory.html)
Brad Christy 11-18-2025 11:07 AM
Guys,
I know there are a lot of opinions on this….
Doing this cam swap, and addressing the pushrod length setup.
https://cimg0.ibsrv.net/gimg/www.off...043889841.jpeg
Which is better?
Thanks. Brad.
powerboatr 11-18-2025 11:16 AM
Go on you tube
search
Powell Machine and camshaft
dude is a no nonsense genius
Explains everything easy and educates
https://youtu.be/jXu4Bga8Q6E?si=s6MZ3pMcjnPkMrY-
https://cimg6.ibsrv.net/gimg/www.off...0c60710a62.jpg
Brad Christy 11-18-2025 12:09 PM
Originally Posted by powerboatr (Post 4938744)
Go on you tube
search
powerboatr,
I’ve done a ton of YouTubing, albeit I haven’t come across Powell (I’m aware of him). So far, all I’ve seen/heard/read is that you want the left image sweep with the right image contact patch. Unfortunately, with stud mount rockers, that’s not always possible. Sometimes, you just have to choose one over the other. So I’m asking the brain trust their druthers.
Thanks. Brad.
powerboatr 11-18-2025 12:39 PM
Originally Posted by Brad Christy (Post 4938746)
powerboatr,
Thanks. Brad.
agreed, your on right track
The math and phyics from cam to valve stem is deep
I have been an aircraft engine guy since 81
Those engines are set in stone
For longevity, reliability etc .
JaniH 11-18-2025 01:06 PM
This is how i do it, makes sense to me. Keep calm guys 😁
JaniH 11-18-2025 01:11 PM
Having The sweep in The center of The valve tip IS not so inportant as The ammount of The sweep, The less The better.
JaniH 11-18-2025 01:36 PM
BillK 11-18-2025 06:41 PM
Brad,
I feel differently than most. I always try to get the pattern centered. I would rather give up a little lift to have the valve pushed down as straight as possible. But every time it has also ended up with the narrowest pattern. One thing to take note of is that different rocker manufacturers will give different results. You can put a Brand A 1.7 Big Block rocker on a head and it can be almost impossible to get a decent pattern. Take it off and put a Brand B rocker on and it will be perfect. And it can vary from one head manufacturer to another :( :(
You asked for opinions . . . . . :)
Smitty275 11-18-2025 06:41 PM
Scott Foxwell from Straub Technologies gives the best set up in this YouTube video:
As to where the sweep cones out on the valve, be it centered or inside/outside a little doesn't matter. Ed Iskendarian put it best when he said, " thats why theres a roller on the rocker tip." Just so it's not coming off at one extreme of the sweep you'll be just fine.
SB 11-18-2025 07:13 PM
Adjustable guideplates or fixed ?
