Interesting Mercury engine
Yep. That is a huge flat plane V8. I think Ferrari stays below 4 liters. Ford tried a 5 liter, and it did not go well.
I think some of Yamaha's latest 4-stroke outboards are direct injected.
I remember reading an article abt the Yamaha R1 (1000cc motorcycle) flat-plane crank eng a while back. Seems like the only real advantage was the uneven power delivery and how that would give the rear wheel a chance to re-gain traction accelerating out of a corner. Is there any performance advantage in a boat?
You can rev a flat-plane V8 higher, because the exhaust pulses don’t stumble on each other on the way out. It also helps that the crank is lighter, as it is not used as counterweights to the pistons.
(That exhaust issue is what causes the characteristic cross-plane V8 rumble)
