Fuel Pump Recommendation >
Old 01-14-2026 | 08:08 PM
  #31
Guys,
I sent the pump to Weldon to be rebuilt. I got a call from Jim at Weldon this morning. Worse than we thought….
Obvious signs of salt water exposure and being run dry (starved).
He found a really good shape used pump body, and the internals will all be new, plus new motor bearings and he replaced the motor cap with a good used one with considerably longer lead wires. The pump should be like new when I get it back. And all cheaper than a new one, by a good bit. It should be a fair bit quieter, too.
Thanks. Brad.
Brad Christy is offline
Old 01-15-2026 | 09:11 AM
  #32
Good deal,.You`re lucky it didn`t fail on you and take out that new engine1
ICDEDPPL is offline
Old 01-15-2026 | 09:24 AM
  #33
Active Streak: 30 Days
Originally Posted by Padraig
The only time I notice mine is when I have the engine hatch up and turn the key to on. I hear a brief humming noise and then it stops. With the hatch closed I have to listen hard. Never noticed any noise after starting or while running.
Maybe a dumb question but mine is mounted low and horizontal by Eddie Young. Could your mounting position and location cause it to work harder and create more noise?
Padraig
Is the noise reducing because it is loaded up and under pressure or because it has a shut off built into it?
Helmwurst is offline
Old 01-15-2026 | 09:32 AM
  #34
I hate to admit that I am not smart enough to answer that question. I have always assumed that it built up pressure and shuts off.
Padraig
Padraig is online now
Old 01-15-2026 | 09:42 AM
  #35
Guys,
Thanks. Brad.
I knew it! One of mine was rusty inside. I'm sure he already told you as he did me, to make sure you seal it up in a couple spots when you get it back.
Diamond Dave is offline
Old 01-16-2026 | 09:01 PM
  #36
Dave,
He did not. At least, if he did, I don’t remember it. I’m guessing I’ll get an email or there will be a note. We’ll see. I will most likely install it as soon as I get it. Not sure if that qualifies.
Thanks. Brad.
Old 01-29-2026 | 04:40 PM
  #37
Guys,
Got the pump back today. Looks clean, but just like it’s when I sent it out. No surprises. Now to mount and connect it. I’m thinking I’d like to use a connector for the electrical, instead of hardwiring it. Is this the route to go, or should I just hard wire it?
If so, is this a viable option?
Thanks. Brad.
Old 01-30-2026 | 07:06 AM
  #38
that connector should work fine
snapmorgan is offline
Old 02-03-2026 | 09:24 AM
  #39
Guys,
All back together. Freshly rebuilt fuel pump, double rubber grommet mounting. At the very least, I can say the pump won’t be transmitting any noise it might be making to the hull. It’s as quiet as it’s gonna get. I hope it will satisfy the CFO.
Thanks. Brad.
