trim tab switch >
trim tab switch
trim tab switch
Old 01-21-2003 | 05:52 PM
Hot Boat's Avatar
Team Dysfunctional
Default trim tab switch
My boat was equipt with bennett tabs but i am switching to K Plains . I havent got the trim pumps for them yet but I was looking to see if the old bennett switch would opperate the two new pumps or do I need a new switch and more wires. Also if anyone has a wiring diagram to show me how to wire this setup i would apreciate it . thanks
Paul
Hot Boat is offline
Old 01-21-2003 | 07:57 PM
doug hess
The circuit is real simple. Switches send power to motor up or down coil, and to up or down solenoids. Only no-no is you can't engerize both the up and down motor coils at the same time or it will blow fuse. To avoid that problem use relays and diodes in a lock out circuit. Switches for the motor should be at least 20 amps unless your using the relays.
Rambunctious
08-04-2008 07:34 AM
Sydwayz
07-05-2007 09:40 PM
26sonic
Sonic
8
05-12-2006 09:23 PM
Sydwayz
16
09-15-2005 11:37 AM
Smitty
Baja
0
08-01-2003 12:22 PM
