Engine weights? >
Engine weights?
Engine weights?
Old 01-26-2003 | 11:26 PM
outlawinil's Avatar
Default Engine weights?
Pulling out 7.4L 310MPI motors and putting in 502 Mag EFI or 500 HP. What do these motors weigh fully dressed? Will 1000 lb chain hoist do the job?
outlawinil is offline
Old 01-27-2003 | 12:38 AM
puder's Avatar
speel chekk this fokker!
yeah it should. pull teh exhuast to be on eth safe side plus it make it easier to move around. That alone will knock off 100 lbs or more if you have stock cast manifolds. Ar eyou using achhain hoist or charry picker? I used my cherry pick on the 500lbs extension setting once and was fine. I need a few extra inces to get it out of my truck. I know trhe manufactureers figure in a 50% safety margin when rating that stuff. So you can go over (once in a while) and still be fine.
Pardon me, while I whip this out!
puder is offline
Old 01-27-2003 | 01:05 AM
Audiofn's Avatar
Charter Member #232
Ya I would pull the manifolds otherwise you will be on the edge of the things capacity. With the manifold off you should be fine. I use a 1.5 ton hoiste to be totally safe.
Jon
Put your best foot forward!
Audiofn is offline
Old 01-27-2003 | 05:33 AM
David's Avatar
dressed weight is in the 1200 lb more or less range.
David is offline
Old 01-27-2003 | 08:16 AM
Brad Perry
A one ton unit should work, as long as it's not a Chinease one! No offense, but I figure a 4x safety margin when buying the cheap import stuff.
Old 01-27-2003 | 08:38 AM
formula31's Avatar
Yea, I wouldnt try less than a 1 ton (2000lb). I had an electric hoist rated 1000 lbs and although it would pick the engine up, the brake wouldnt hold. I think fully dressed stock merc motor with all cast iron manifolds is easily 1200lbs if not more.
formula31 is offline
Old 01-27-2003 | 11:11 AM
RLW
I was always under the assumption that a Mercruiser Big Block with a Bravo drive package weighed in around 1200 lbs.
RLW is offline
Anger Management
8
12-29-2007 10:42 AM
berns29scarab
36
11-24-2006 03:35 PM
Jnewton
5
10-09-2005 04:58 PM
airshares
Scarab
15
05-05-2005 07:41 PM
airshares
6
06-26-2004 09:27 PM
