Battery charger died >
Old 02-04-2003 | 11:20 AM
Default Battery charger died
Anyone know where to get a battery charger rebuilt/fixed? I have no idea what type of shop would do this work. Maybe have to send back to mfgr? (Guest)
ThirdBird is offline
Old 02-04-2003 | 11:50 AM
You might try a alternator/starter rebuild shop?
Or West Marine has them starting at 299.99
Bajaforce is offline
Old 02-04-2003 | 12:09 PM
cheitman
Me too! I have a Guest 2615 which no longer works. I called Guest and they no longer make that model, and won't fix it either. They are trying to sell me an equivelent model for around $300.00. I would think it could be fixed.
Old 02-04-2003 | 03:51 PM
mopower's Avatar
Toxic FORMULA
When a battery charger dies , it's usually just a bad diode.
These can usually be checked with and ohm meter. Placing the leads of the meter across the diode... should be almost 0 resistance in one direction and almost infinite in the other direction. If it's open both ways , it's bad. Most electronic supplies should be able to sell you a replacement
mopower is offline
Old 02-04-2003 | 06:37 PM
doug hess
Mopower is right on. Usually it is the simple things, poor connections, broken strains in insulted wire, diodes, switches, etc.
RadioShack has some parts and www.allelectronics.com has big selection, cheap. Be careful about diodes. They must have the right current minimum rating for the power ones. If they are zieners then the voltage is critical. If repair is beyond your talents try a local TV repair shop.
Old 02-05-2003 | 06:26 AM
Thanks for the responses guys. I have a local shop that is a combination Radio Shack/TV repair shop. I'll give them a try.
Here's Johnny
Sonic
8
06-26-2007 04:15 AM
RJ1340
07-19-2006 05:17 PM
powerquest 380
Powerquest
22
04-13-2006 09:06 PM
tpmarine.com
New Products and Member Discounts
4
02-02-2006 09:50 AM
KN
Sunsation
2
05-17-2002 12:24 PM
