Adjusting trim sending unit? >
Old 02-19-2003 | 06:43 AM
Default Adjusting trim sending unit?
My starboard trim gauge is way off from my port one. Any body have any recommendations on adjusting them. Looks like lower unit has to be pulled to get to the lock down screws on the sending unit? If so, Do you have to keep R & R the lower unit to adjust the sender just right. They are bravo drives. Thanks in advance for any help.
Jeff
Bajaforce is offline
Old 02-19-2003 | 06:49 AM
Dave M's Avatar
Veteran: Navy
I dont think you have to pull the outdrive to adjust it. There should be two screws on the sending unit. Loosen the screws and turn it slightly. I switched mine to a mechanical indicator. They seem to be less problematic.
Dave M is offline
Old 02-19-2003 | 06:52 AM
Dave,
Where did you get your mechanical indicators and what is involved in installing them?
Thanks,
Jeff
Old 02-19-2003 | 07:20 AM
Dave M's Avatar
Veteran: Navy
I got all the parts from the Gaffrig catalog. You need the actuator kit, a thru hull fitting, cable, and dash panel. Go to http://www.livorsi.com
Dave M is offline
Old 02-19-2003 | 08:04 AM
Thanks alot Dave
Old 02-19-2003 | 09:39 AM
Iggy's Avatar
Not sure about the Bravo setup, but on my Alpha I have to turn the drive to the left to access the forward screw.
I then turned it back to straight, leveled the cavitation plate with the keel and set the gage to center, locked down the sender and called it done.
Not too hard.
Iggy is offline
Old 02-19-2003 | 12:51 PM
Thanks Iggy
Old 02-19-2003 | 11:31 PM
Reckless32's Avatar
Rough Seas Lie Ahead
You can remove it and check the internal parts. Sometimes the teeth the fit into the drive get worn and slip a bit for an inaccurate and inconsistent reading...
Reckless32 is offline
Racerngr1
Fountain
2
07-25-2008 12:04 PM
Bigracks
Drives and Lower Units
2
06-14-2007 11:07 AM
waterboy222
2
06-02-2007 08:28 AM
Shore Thing
3
07-13-2006 11:55 AM
RUSSSR1
4
08-14-2002 05:01 PM
