prop testing procedure? >
Old 04-22-2003 | 06:01 PM
26sonic's Avatar
Default prop testing procedure?
when testing different props what variables should be used? should i test with full tank of gas ? how many people aboard etc.?if you tested a prop say with full tank of gas and just the driver aboard and got a wot of say 4900rpm's , how would this reading be affected with a full load of people? would the rpm's drop?
26sonic is offline
Old 04-22-2003 | 09:04 PM
SteveDavid's Avatar
Charter Member #1093
Hi 26 Sonic,
It's not important how many aboard, fuel levels, etc. So long as you have the same constants for each prop test. For example full fuel, 4 passenegrs, 88 degrees, 70% humidity etc. If the constants stay constant you'll get a reliable comparison of props.
For the most real world tests, have your boat loaded as you would on a normal outing, as opposed to a light load, low fuel etc. What you're seeking is a prop that will run at your engines upper RPM limits while the boat is loaded as normal.
Good luck,
Steve
SteveDavid is offline
UNSANE
Prop Talk
4
01-25-2008 09:37 AM
tssteph
Prop Talk
13
06-06-2005 06:45 PM
klaw
11-09-2004 12:47 PM
baja27
Powerplay
10
04-16-2004 08:12 AM
Kokopelli
07-11-2002 10:35 AM
