MSD Wiring
Old 05-04-2003 | 10:24 PM
rbtnt's Avatar
Default MSD Wiring
Anyone clear up MSD ignition problems by separating the wires going from your MSD box to the your coil from the wires that go to your distributor?
rbtnt is offline
Old 05-05-2003 | 07:51 AM
Adivanman
Lightbulb
Yes.
MSD is very clear that the magnetic pickup wires going to the distributor should not be run with any other power carrying wires - including but not limited to the coil wires. The pickup wires can be very sensitive to electrical interference and you can end up with a variety of issues - most of which manifest themselves as erratic timing or randomly dropping cylinders. It seems that the newer the MSD unit, the more sensitive they are to noise.
Old 05-05-2003 | 09:40 AM
rbtnt's Avatar
Thanks for the info.
rbtnt is offline
Old 05-05-2003 | 08:14 PM
rbtnt's Avatar
Can I replace the distributor wires with shielded wire and ground one and keep it in the split loom with the other wires? I'm just trying to keep the wires neat.
rbtnt is offline
nocigarette
29
06-30-2008 06:59 PM
Monty
04-07-2004 08:37 PM
blue thunder
6
06-02-2003 04:04 PM
puder
6
05-27-2003 10:42 PM
BGIII
12
08-11-2002 09:20 PM
