Hard Anodizing?? >
Hard Anodizing??
Hard Anodizing??
Old 05-05-2003 | 02:30 PM
HiPerf2000's Avatar
Question Hard Anodizing Blower Pulleys ??
i had to custom make a couple blower tensioner pulleys out of 6061 aluminum. Someone told me i should have them hard anodized so they do not wear from the belt pressure and heat generated from the belt spinning.
anyone have any thoughts on if i need to get this done. i could see if it were a main crank pulley or top blower pulley that has no give, but this is the spring loaded tensioner pulley that will give under pressure via the spring.
HiPerf2000 is offline
Old 05-06-2003 | 08:40 AM
HiPerf2000's Avatar
anyone??
Old 05-06-2003 | 04:29 PM
HARD ANODIZING WONT STOP THE ALUMINUM FROM WEARING
IT IS MORE FOR CORROSION RESISTANCE THEN A WEAR RESISTANCE
SLINGSHOT is offline
Old 05-06-2003 | 08:57 PM
Rambunctious's Avatar
i'de have to differ on the wear. we hard coat annodized some automotive interior parts i designed because of the excessive spring pressure and cycles applied onto the part. hard coat is something like 6 points shy of diamond hardness in rockwell measure, if i remember. don't hold me to that number, but jsut DANG hard!!!.
I can't answer if it is necessary though. it is a cool platinum look. at least the process we used. not sure if you can get clear hardcoat annodizing.
Rambunctious is offline
Old 05-07-2003 | 11:17 AM
HiPerf2000's Avatar
i called the local anodizing place around here and they do have a clear hard anodize...I may go in that direction because the aluminum has a high polished look right now.
i know that it is very, very hard stuff because someone once gave me a part to machine that had been harden anodized, and i couldn't cut through it.....i burned up 3 tools before I quit gave it back to him.
17
02-06-2005 11:27 AM
LubeJobs42
01-16-2005 06:18 PM
tssteph
6
06-14-2004 10:56 AM
US1 Fountain
08-25-2003 09:22 AM
US1 Fountain
02-11-2002 02:34 PM
