motor change -  what works? >
Old 06-18-2003 | 06:28 PM
Michael Martin
Thumbs up Thanks Curt
I just didnt know if the increase of the HP and torque would make a shower worth the price.
I found a 93 Sea Ray that's an insurance job. The boat came off the trailor & it busted the bottom up really bad but the motor & drive is fine. I might just buy it ($900.00) & strip it. Its got the 350 w/ the alpha drive & the trailor is in good shape. Needs a fender but thats cheap enough to fix. Probably save me a lot of money in the long run.
Curt hows everyone been? I havn't see you guys on the lake this year. I hope Miss Martha is well.
Mike
Old 06-19-2003 | 04:29 PM
HyperBaja's Avatar
Default Re: Downside?
Originally posted by Michael Martin
Tommy it sounds like there may be a downside to this that your holding back. If I'm making a mistake please let me know. I have also looked into getting a setback bracket and pulling the I/O & going for an OB.
I know I'd have to reglass the transom etc. But I've done that before. I just figured swaping to a v8 would be less expensive & better overall.
Mike
downside...
1.I am 16 and $ is hard to come by
2. Gas
3. Weight. My 175 V6 will run right next to the 350 with 240 hp in the same boat.
HyperBaja is offline
Old 06-19-2003 | 04:30 PM
HyperBaja's Avatar
Originally posted by IRONMAN
A 19" pitch prop should put you close to 40mph at 4900rpm's with that ratio. are you using GPS for speed? Verify the gages both tach and speedo for accuracy so you have good data to start from. I have 2 friends with 4.3's in about the same size boats 19' and 21' and they both run over 40 the 21 chris craft is close to 48 on gps on a good day. good luck
With 1/2 tank and 1-2' I run 45.0 on Garmin at 4900. I think that is somewhere around 7" slip....not bad eh?
Old 06-19-2003 | 06:32 PM
Michael Martin
Well I'm not majorly concerend with speed as this is the wifes toy. I'm just tring to get it to perform like I think it should. I have a 17'vector with OMC power that takes care of my need for speed when it pops up.
Thanks for al the help guys
Mike
Buddy OO
07-07-2005 12:20 AM
powerguy
27
12-29-2004 01:37 PM
Danny_Ocean
5
04-12-2004 07:22 PM
excursion
06-07-2003 08:24 PM
Dean Ferry
45
11-11-2002 03:34 PM
