Heads questions >
Heads questions
Heads questions
Old 07-22-2003 | 08:43 PM
Tinkerer's Avatar
How old are your rocker arms- what brand are they?
I broke some studs last year and traced the problem to bad rocker arms. Hold the bearing shaft and move the rocker in your hand and see if it is smooth. I replaced the rockers and installed ARP studs.
Tinkerer is offline
Old 07-22-2003 | 09:44 PM
Dennis Moore
I am sure that stud girdles will help if you have room underneath your valve covers. Lay a straight edge across the studs and see if any are out of alignment with each other. This would indicate that they are probably out of alignment with the valve stems.
Sincerely
Dennis Moore
Old 07-22-2003 | 10:46 PM
Tinkerboater, new rockers, and they are smooth.
Thanks Dennis I'll check the alignment.
88 MACH 1 is offline
Old 07-23-2003 | 05:52 AM
turbo2256
Some of my rules for valve train set ups.
Long life .500 and under lift for small blocks
.550 and under lift for big blocks
.600 and over stud girdles or shaft mounted rockers.
Old 07-23-2003 | 07:56 AM
jdnca1's Avatar
www.jesel.com
jdnca1 is offline
fastlane40
5
01-29-2008 06:31 AM
fastlane40
13
01-11-2008 04:56 PM
iamfaster
3
01-08-2005 06:48 PM
Dave1972
6
12-09-2003 02:16 PM
Red Stripe
7
05-28-2002 06:48 AM
