Need Help-500 EFI Overheating
Answering some questions from talking to Fountain 38 today....
Leon Dereberry is working on it now... (Lake Texoma),
the sea pump has been rebuilt, the thermostat & housing replaced, bypassed the oil cooler & cool fuel (running nothing but the engine off the pump) & it still is overheating. The heads are coming off Weds to check for the correct head gaskets & cracks..... this engine only has 30 hours on it...???? go figure..!!
i have a 35 motion with 500 efi motors. occasionally the port motor goes up from 150 degrees to 180 for a bit then back to 150. new thermostats were installed, new temp senders,water pressure is perfect at about 25 psi wot.every time the temp goes up i shoot the heads with a laser temp gage, and sure enough the temp is really 180. any ideas anyone?
