HP engine mounts >
HP engine mounts
HP engine mounts
Old 10-08-2003 | 02:24 PM
I think I've seen dimensions of the plates on a merc parts website. Dont remember where though. BTW, they have both side by side and staggered, make sure you get the right one.
But if they're too big, just cut them off. If too small use 6 x 6 L angle.
As for the rear mount, you usually buy a new bell hosing so the starter (top mounted) and tranny input flange seat fully. Or you can mill the plate thickness off the front of your bell housing. But the only reason I can see to use the rear plate is for a staggered motor using a driveline output. Even SSM drives have tranny tailstocks that ride on the transom plate.
If you want to use a bottom mounted starter, just cut a hole in the plate.
Gary
Gary Anderson is offline
Old 10-09-2003 | 09:41 AM
SSComp's Avatar
Thanks Gary. Lots of helpful info there.
SSComp is offline
Old 10-09-2003 | 11:57 AM
Found the diagram with dimensions.
Side by side:
http://www.dolleroffshore.com/parts....pn=4269&r=4440
Staggered:
http://www.dolleroffshore.com/parts....pn=4269&r=4441
Old 10-16-2003 | 04:02 PM
SSComp's Avatar
It looks like I only have about 21" between the stringers. It also looks like I can take the base Merc front mounts, cut to size and add some strengthening.
I'll let everyone know how it goes!
SSComp is offline
Old 10-16-2003 | 09:25 PM
martiniboat's Avatar
From: Brussels, Ont. CAN. Landlocked between Lake Huron, Ontario and Erie
FYI, if you get 'stuck' give me a shout. I'd be happy to help with any custom needs. Especially the unique stuff.
Sincerely,
Brian Kamrath
martiniboat is offline
johnnyboatman
Fountain
12
09-22-2008 08:56 PM
ghittner
10
04-08-2006 12:00 AM
ccarloss
8
11-03-2004 06:41 PM
Chart
06-09-2002 10:08 PM
NASTY HABIT
3
03-21-2002 08:08 PM
