Prop hubs?
Old 01-09-2002 | 04:51 PM
PSYQUATIC
Post Prop hubs?
Is it true that you shouldn't run a solid hub prop on an alpha drive?
Old 01-09-2002 | 09:12 PM
Goodfella's Avatar
GOT MERC?
Question
How much HP?
Goodfella is offline
Old 01-10-2002 | 10:57 AM
PSYQUATIC
Post
Around 325hp each.
Old 01-10-2002 | 01:13 PM
puder's Avatar
speel chekk this fokker!
Post
i runa solid hub on my alpha with a mirage+
I always heard rubber hubs are good if you hit something, that way eth b=hubs breaks and not your drive. But that is true with any drive not just and alpha
Pardon me, while I whip this out!
puder is offline
Old 01-10-2002 | 02:15 PM
Goodfella's Avatar
GOT MERC?
Wink
A rubber hubbed propeller will not last with 325 Hp put on it. You need to run a solid hub propeller.
Old 01-10-2002 | 06:56 PM
Mbam's Avatar
Offshoreonly Advertiser
Post
Due to the way the lower unit shifts on an Alpha (dog clutch - very abrupt engagement) the rubber or cushion hub is needed to absorb the shock during engagement. It is not so much a question of HP. The recent square bore Mercury props (Mirage +, Bravo 1)use plastic instead of rubber for less than 400 HP. After that a solid insert is reccomended.
As Goodfella says, the rubber hubs were not good for anything with any power.
Mbam is offline
Old 01-10-2002 | 09:59 PM
PSYQUATIC
Post
Thanks for the info. I'll try for plastic hubs on my new props.
FasTech 292
06-10-2008 10:28 PM
alter ego
1
03-04-2004 06:48 PM
alter ego
5
03-01-2004 01:44 PM
mjuwalters
0
07-21-2002 09:18 PM
mjuwalters
8
01-17-2002 04:51 PM
