Prop change? >
Prop change?
Prop change?
Old 10-09-2003 | 01:06 PM
Default Prop change?
Im have a 26, 4 blade I thinking about putting on a 2002 288 sunsation 496mag 375hp..It has a 24, 4 on it now and rpm WOT is 4700-4800 67mph..Is the 24 the best prop for this boat?
bcolmsted is offline
Old 10-09-2003 | 01:53 PM
Joe's Avatar
Joe
Offshore Cowboy
Try a lab'd 24 first - if you can. It might give you the extra mph over the stock 24. Or, get your 26 worked on.
Joe is offline
Old 10-09-2003 | 04:48 PM
HOUSTONPROP's Avatar
Default Re: Prop change?
it just depends on what you want? all out top end ? midrange cruising ,hole shot? the four blade will surley give you a smoother ride in rough water,I would add a litlte pitch and lab the prop. you already have a good one to work on.
HOUSTONPROP is offline
Yamaha 225
Prop Talk
10
10-08-2008 05:43 PM
apexer
3
07-08-2008 10:18 AM
Elite Marine
0
04-08-2004 06:49 PM
wes29
Powerquest
4
09-05-2002 10:00 PM
Keith
Scarab
0
08-31-2002 09:23 PM
