water pressure >
water pressure
water pressure
Old 11-28-2003 | 09:08 PM
johnnyboatman's Avatar
Default water pressure
will 1/4 inch holes in a exhaust riser next to the big hole allow a decrease in water pressure.
johnnyboatman is offline
Old 11-29-2003 | 09:09 AM
what are you trying to accomplish? tell us about your setup
carreraboat is offline
Old 11-29-2003 | 02:58 PM
i installed new revolution manifolds, the risers dont have big enough water outlets, the manufacture said to drill 1/4 holes next to there factory outlet to lessen water pressure. it had 15 at wot, now it has over 30wot.
Old 11-29-2003 | 03:17 PM
if they manufacture is saying to do it go for it they would know better than most
Old 11-29-2003 | 08:44 PM
ttt
Old 11-29-2003 | 10:37 PM
CAMS-SHAFT
Believe it or not 1/4" hole will help. You will still need to check the water psi after drilling these holes. Ideal block psi is 18-25 psi to much more than that and you will have problems with head gaskets and losing hoses. You can also do a pop-off regulator.
Old 11-30-2003 | 11:32 AM
Kanookstr's Avatar
32' SUNSATION
Go with one of these. this way your sure and you won't have to drill and tap holes
Merc pressure relief
Kanookstr is offline
LostinBoston
18
03-26-2006 07:23 AM
BOATMAN302
3
02-28-2006 08:17 PM
Zanie
5
03-10-2005 10:58 AM
28Eliminator
11
06-22-2004 10:43 PM
merlin540
08-28-2002 05:45 PM
