Camshaft end play???? >
Old 12-11-2003 | 01:49 PM
KNOT-RIGHT's Avatar
Default Camshaft end play????
I am replacing the timing chains in these 540's.
they are 741 roller cams with the cam button that rides against the timing covers.
The new timing chains Billet Comp cams #cca-7110.
Comes with a new Torrington bearing behind the cam
sprocket. The old timing sprocket had the bearing also.
When I install the timing cover there is no longer any
camshaft end play ( or very little).
After inspecting the cam button I notice a little c clip
in which when removed gives access to a little torrington bearing and to two thrush washers/shims.
Is this where you set the Camshaft end play by changing the thickness of these Washers??
Please respond
Gerry
KNOT-RIGHT is offline
Old 12-11-2003 | 03:29 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Set the endplay by bending the timing chain cover. You can use a socket and place it were the button makes contact with it and smack it with a hammer making a recess in the cover. Sometimes different gaskets will make the correct clearance. Check clearance when it is assembled
US1 Fountain is offline
joev01
0
11-20-2007 08:41 AM
cigarette39
09-12-2006 08:24 AM
steve stanko
7
03-30-2004 02:51 PM
FunHome
06-10-2002 11:12 AM
