Stringer Replacement Formula 302 >
Old 10-11-2005 | 06:13 AM
  #161
Audiofn's Avatar
Charter Member #232
Default Re: Stringer Replacement Formula 302
I would not worry about blue printing it, on a boat like this you will not see much benifiet unless you plan to put HUGE power in it. I would make a cradle for it. Use 2x12's for support. Do all that and check your bottom first. The bottom on these things is very thick so it is not likely that it goes out of wack if you take some precaucions.
Jon
Put your best foot forward!
Audiofn is offline
Old 10-11-2005 | 09:26 AM
  #162
Prater's Avatar
I am going to attempt the blueprint just for experience. I am doing this work on an older boat that was free. I do not want to be ctting and grinding on a new boat that cost me well over 50K, but if I learn on this one I may do it to something newer in the future. Thanks for the help
Prater is offline
Old 09-11-2007 | 11:30 AM
  #163
AIR TIME's Avatar
Ttt
AIR TIME is offline
Old 09-14-2007 | 10:59 AM
  #164
Hydrocruiser's Avatar
Arrow
They did a good job at getting the tank to fit and hold...
Hydrocruiser is offline
Old 03-17-2008 | 10:25 PM
  #165
PhantomChaos's Avatar
Jon.....what's the latest????
PhantomChaos is offline
Old 03-28-2008 | 02:02 AM
  #166
McFly?????????
Old 03-28-2008 | 07:22 AM
  #167
Audiofn's Avatar
Charter Member #232
This job was done a LONG time ago. Building one house and restoring another is keeping me from finishing up other things
Audiofn is offline
Old 03-28-2008 | 02:31 PM
  #168
Did you finish the whole boat? Did I miss that?
Old 04-04-2008 | 07:16 PM
  #169
AIR TIME's Avatar
Thumbs up
nope you didn't miss it, he's got all the goodies and DONZI 18 to fly around in while working on the houses.
AIR TIME is offline
Old 04-05-2008 | 05:40 AM
  #170
Audiofn's Avatar
Charter Member #232
Not finished with the paint and all but the stringers are in under the cockpit. I am thinking about doing the ones forward in the cabin with a insert like Formula uses now. Will have to have it engineered but it woudl save me HUGE on the weight.
Audiofn is offline
