HP500 rebuild cost? >
HP500 rebuild cost?
HP500 rebuild cost?
Old 01-26-2004 | 03:16 PM
Default HP500 rebuild cost?
whats the cost of a full top and bottom end rebuild for a pair of 500s?
dreamer is offline
Old 01-26-2004 | 06:49 PM
While doing it, it might be worth only a small additional to add a longer crank and make a 540 out of it. The price of alumn heads these days it makes more sense to add them instead of rebuilding yours. You can buy a 540 shortblock for under $5000 and heads for another $2000 and then sell your longblock intact for $2000.
Or sell me your motors complete.
cobra marty is offline
Old 01-26-2004 | 07:20 PM
Crazyhorse's Avatar
If you take it to a reputable shop and they machine everything to factory tolerances I'd expect to spend around $4000. That should come with a written warrantee, usually 12 months.
Crazyhorse is offline
Old 01-26-2004 | 09:15 PM
Infomaniac's Avatar
I do the HP500 to 540" conversions for $4,750.00
Eagle or Scat crank and rods, J&E pistons, Crane hydraulic roller, Isky red zone lifters and springs. Including all "routine" overhaul parts, machine work etc.
Have two in work now.
Infomaniac is offline
Old 01-27-2004 | 06:39 AM
Canada Jeff's Avatar
infomaniac, is it just as easy with the efi version? What hp do you get out of the conversion?
I need to do My hp500efi soon.
Canada Jeff is offline
Old 01-27-2004 | 09:51 AM
Infomaniac's Avatar
648 HP requires a few more hundred RPM than the stock rev limiter allows to get that HP.
Have not done an EFI. It would require a reprogram of the ECU. I would be happy to take care of the long block portion. Not sure who to recommend for the ECU.
FASTERDAMITT
07-24-2008 08:27 PM
budandfun
06-27-2007 02:52 PM
BadDog
10
05-18-2006 09:19 PM
Bill272
19
10-29-2002 10:51 AM
Raypanic
03-10-2002 08:42 AM
