Shift Cable Bellow >
Shift Cable Bellow
Shift Cable Bellow
Old 03-12-2004 | 09:21 AM
robyw1's Avatar
Question Shift Cable Bellow
Can the shift cable bellow on a Bravo be replaced without removing the drive? The cable is in good shape and shifts fine.
Roby
robyw1 is offline
Old 03-12-2004 | 11:11 AM
nixter's Avatar
The drive has to come off and the shift cable has to
be undone from the bell housing and transom assembly.
Then you undo the clamp that is pinched/crimped over
the shift cable (keeps water from leaking thru the shift
cable) and undo the stainless steel clamp on the end
of the bellow that secures it to the transom assembly
and slide the shift bellow off and put the new one on.
I would highly recommend checking/changing the
shift cable also if you had water leaking in. Hope this
helps.
nixter is offline
35 White Lightning
Fountain
2
11-07-2008 06:38 PM
rrentsch
Powerquest
13
11-06-2007 02:56 PM
DrFeelgood
Drives and Lower Units
5
11-05-2007 09:42 AM
atthelake27
5
07-23-2007 08:09 AM
obnoxus
0
05-15-2002 06:18 PM
