Bravo Drives? 1 Or 3? >
Old 03-24-2004 | 07:58 PM
Default Bravo Drives? 1 Or 3?
I will be replacing my bravo 1's this summer. I have a 29 formula cruiser with twin 454's Is their any gain in performance with the bravo 111, I have heard that with through hub exaust the bravo 111 restrict's the 454's.
Formula29 is offline
Old 03-25-2004 | 12:15 AM
Formula29:
Bravo III's are better for bigger heavier boats that need extra push to get them up on plane easier, however they will cut top speed on your boat probably about 5 mph and they are slightly more exhaust restrictive on through the prop exhaust only.
Raylar
Raylar is offline
Old 03-25-2004 | 07:45 PM
Ric232
The exahust restriction is easy to fix. Mercury issued a service bulletin a few years ago on this issue. Simply replace the exhaust "bellows" with an exhaust "tube". The tube is a Mercury part. With the tube, there is not an airtight seal where it connects to the outdrive. It allows more exhaust gases to escape.
Old 03-26-2004 | 06:09 PM
Thank's for the input, I don't think I could bare to loose 5m.p.h "Need more not less!
Old 03-27-2004 | 02:56 PM
mcollinstn's Avatar
B3 isn't particularly stronger than a B1.
The advantage is that a B3 has no steering torque (which is a non issue in a twin application since the two drives cancel each other out), and a much better BITE on the water. Low speed response at idle speeds is far improved, and prop slippage coming out of the hole is no longer a problem.
Disadvantages are: expensive props. well documented corrosion problems in saltwater. expensive props. and expensive props.
mcollinstn is offline
CN24
Swap Shop
2
11-16-2008 02:19 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
sejman
10
06-06-2003 11:52 AM
