Mercruiser Silent Choice >
Old 04-16-2004 | 12:06 PM
Default Mercruiser Silent Choice
Question for you guys, I have the mercuiser system with the air pump. I need to change the air lines out and Merc wants like 50 bucks for the tubing. What is the size of this tubing? I know that it is a rigid type tubing. Is there tubing that can be purchased at a hardware store that will work for this application? Thanks for the help.
Brian
tmthunder is offline
Old 04-16-2004 | 07:34 PM
chubbytug
I just replaced all of mine. I went with the quick disconnect type fittings, and 1/4" id plastic tubing. I used all Parker stuff that I found at a local hydraulic supply house.
Old 04-17-2004 | 06:55 AM
INDY27's Avatar
how much did you spend?
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 04-17-2004 | 01:05 PM
MnFastBoat's Avatar
Charter Member#157
have plenty of it upstairs in our parts room
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 04-17-2004 | 02:39 PM
powerguy's Avatar
Home depot - about $5. I did mine - worked great.
powerguy is offline
Old 04-18-2004 | 06:38 AM
Thanks for the input. I will look at the Depot next time I am there. What size fittings are used on the acuator side of the tubing??
Brian
magicmoments
21
04-05-2010 06:42 PM
ingveys
1
06-10-2006 11:55 AM
mfb357
12-03-2003 05:30 AM
cig1988
16
01-22-2003 07:43 PM
edb07
3
07-22-2002 01:03 PM
