BBC Fuel pump clearance...has this happened to you? >
Old 04-19-2004 | 08:29 PM
Danny_Ocean
Default BBC Fuel pump clearance...has this happened to you?
I replaced the automotive type fuel pump (Carter) on my 454 with an AC/DELCO marine fuel pump. The mounting flange on the old pump was 1/2" ~ 5/8" thick and allowed the pump to sit away from the block. The flange on the new pump is about 1/4" thick and, after mounting with shorter bolts, hits the brass plug that allows access to the fuel pump drive rod. This lack of clearance won't allow me to fully tighten the pump and an oil leak has occured.
Is there a different type plug to be used in this situation?
Note: This is the fuel pump that is stand-alone from the raw-water pump.
Thanks in advance,
D. Ocean
Pompano Beach, FLA
Old 04-20-2004 | 06:45 AM
gmhdfan's Avatar
Chevy-Harley fan
What do you have now for a plug? Square head sticking out. If so use a flush mount plug. (allen or square hole)
Pete
gmhdfan is offline
Old 04-20-2004 | 07:27 AM
Danny_Ocean
Yes, the previous owner installed a brass plug with a head on it. I'll try a matching-size allen plug.
Thanks,
D. Ocean
Pompano Beach, FLA
Old 04-20-2004 | 06:13 PM
Danny_Ocean
Picked one up today from BAM. They didn't charge me for it. Good guys.
Thanks all,
D. Ocean
Pompano Beach, FLA
Dueclaws
Swap Shop
10
04-28-2024 01:43 PM
BillR
11
07-29-2022 06:31 AM
dmaxx3500
Do It Yourself, Boating on a Budget
13
08-05-2008 04:37 PM
cheitman
2
05-14-2003 06:58 AM
