Dominator problem >
Dominator problem
Dominator problem
Old 04-26-2004 | 06:27 AM
Excalibur
Unhappy Dominator problem
I have a 604 with a 1050 dominator. Rebuilt the motor this year. The dominator secondary accelorator pump did not seem to work right so i took it apart and blew it out. Seemed o.k. Put it on the boat, everything sounded good. Revved it up a few times and it started loading up. Looked in the carb and gas was pouring down one of the secondary venturis. Rev it easy and sounds great. Rev it a little harder and it fouls plugs. Any suggestions or know anyone good with these carbs?
Old 04-26-2004 | 12:16 PM
krypto 1 in CT
its either got to be somthing (dirt/rtv) in the needle and seat or in the metering block or fuel pressure is set to high.did you check the needle and seat? if the needle has somthing in it and isnt closing thats your prblem.the only other thing i can think of happened to me on a 1050 years ago the metering block was warped and when the motor sat overnite the bowl went dry.gas dripped down the motor.after messing with the carb for weeks i put on a new metering block and the problem was solved.
Old 04-26-2004 | 12:26 PM
Krumbsnatcher's Avatar
Default 1050 Dominator
I have the same carb, lower your fuel bowl. Remember these carbs are geared to run not idle.
On another note what is your starting ritual. I give mine two considerable pumps turn the key as i give her another pump and she fires hard.
Krumbsnatcher is offline
Old 04-27-2004 | 08:41 AM
Registered User
Get a Holley 8082-1 you wont ever go wrong with this piece.
MIAMIBOYZ is offline
Old 04-27-2004 | 11:04 AM
PatriYacht's Avatar
That's what I use on 540's. They idle and run perfect.
PatriYacht is offline
Old 04-27-2004 | 12:54 PM
mr_velocity's Avatar
Default Re: 1050 Dominator
yup, that's what I do. Haven't had to touch my 1050s in 6 years.
mr_velocity is offline
Old 04-29-2004 | 06:17 AM
Excalibur
I have a 8896-1, so whats the great advantage of the 8082-1 except for the linkage difference.
Secretformula
Sunsation
1
08-26-2008 01:46 PM
zougiejr
08-14-2007 09:36 PM
nocigarette
27
07-11-2007 09:51 PM
timucin
25
12-05-2003 12:00 AM
BruceK
Sunsation
0
07-25-2002 12:57 PM
