Intake valve length? Merlins...
I need some intake valves for my merlin oval ports anyone know what the length is off the top of your heads????
If your boat has a sail do you ride a horse to the ramp?
I'M SURE YOU KNOW THAT DEPENDS ON WHAT INSTALLED HEIGHT YOU NEED BUT FOR AN INSTALLED HEIGHT OF 1.925-1.950 WHICH IS WHAT YOU WOULD NEED FOR A HYDRAULIC HYDRAULIC ROLLER OR FLAT TAPPET A VALVE OF 5.250. MOST MANUFACTURERS MAKE THEM IN 5.300 YOU MAY NEED TO RUN A SPRING CUP TO GET YOUR INSTALLED HEIGHT. A SPRING CUP IS A GOOD IDEA ANYWAY TO KEEP THINGS STRAIGHT. GOOD LUCK LAZ MESA WWW.MESABALANCING.COM
