Tailpipe transom grommets >
Old 04-29-2004 | 04:22 PM
epeek's Avatar
Default Tailpipe transom grommets
I have a 91 32 fever and am installing new exhaust.
Where my existing tailpipes pass thru the transom grommets,its a little sloppy.Does anyone know where I can buy exact replacements for these? Rex's are three
bolt & mine are four. Could I just put some sealer in
there ? Does it have to be a real tight fit? Any help
appreciated. Rick
epeek is offline
Old 04-29-2004 | 04:56 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
My Fountains have just had a 4 screw hole plastic ring slide over the tail pipes, no gasket. But the space between the tail pipe and the transom cutout is filled with sealer. I use 4200 with no problems.
US1 Fountain is offline
Old 04-29-2004 | 05:56 PM
DanB's Avatar
Charter Member #71
IMCO sells the 4 hole silicone gaskets and the trim rings if you need them.
And yes!!!! they need to be tight. Starts out as a 2" hole and goes to 4" when you push the pipe thru.
I need to get my mind out of the gutter
Dan
DanB is offline
Old 04-29-2004 | 06:20 PM
C_Spray's Avatar
Diamond Member #001
Don't forget to call Brownie at Stainless Marine - (305) 681-7893. They make these by the hundreds.
C_Spray is offline
Old 04-29-2004 | 08:17 PM
epeek's Avatar
Thanks guys. Always get the answer on OSO!
epeek is offline
handfulz28
01-25-2008 12:26 PM
turbosonoma
Fountain
2
07-30-2007 06:18 PM
jez350
Scarab
3
03-12-2007 11:37 PM
redfountain420s
4
08-15-2005 03:05 PM
HiPerf2000
3
09-19-2003 04:03 PM
