Sloppy Rack
Old 05-06-2004 | 12:25 PM
robyw1's Avatar
Sloppy Rack
My 22’ Scarab uses the Telesux rack & pinion steering, Over time is has become sloppy. Is there an adjustment somewhere I can tighten it up? Right now to go straight the steering wheel is turned about 45-deg off center. Can this be adjusted or is it just plain worn out?
Roby
robyw1 is offline
Old 05-06-2004 | 05:57 PM
Probably just wore out. This may be a safety issue. They are not much to replace.
BadDog is offline
Old 05-06-2004 | 07:33 PM
Dave M's Avatar
Veteran: Navy
It could be a problem with your gimbal ring being worn also. Before replacing anything you might want to have a pro look at it.
Dave M.
Dave M is offline
MickeyBoy
Cigarette
3
04-27-2008 11:35 PM
Payton
Drives and Lower Units
0
02-28-2008 05:47 AM
CAP071
01-10-2004 04:22 PM
MIdnightRider
01-15-2003 06:13 AM
