Seized Bravo 1 Drain Plug >
Old 05-23-2004 | 03:55 PM
Kokopelli's Avatar
Default Seized Bravo 1 Drain Plug
Any suggestions? I tried soaking in liqiud wrench overnight.
Kokopelli is offline
Old 05-23-2004 | 05:13 PM
Comanche3Six's Avatar
Default Re: Seized Bravo 1 Drain Plug
You will need a small 3/8 impact gun and a tight fitting to the drain plug screwdriver socket. Square up to the drain plug with the impact gun and give it small bursts, let the drain plug feel the impacts and I believe it will release. The snap on man sells the correct socket. Buy a drain plug and bring it to the snap on truck for an exact fit.
Good luck
Ed
Comanche3Six is offline
Old 05-23-2004 | 06:24 PM
Use an impact driver, the type that you hit with a hammer. Also try pb blaster its the best penetrant there is.
gusman is offline
Old 05-24-2004 | 07:37 AM
Kokopelli's Avatar
Don't know that I've ever seen this type of driver- whats it looklike and where would I get one?
Old 05-24-2004 | 08:51 AM
Dave M's Avatar
Veteran: Navy
I've had success putting a small punch (nail set) on one side of the screw slot and tap it with a hammer.
Dave M is offline
Old 05-24-2004 | 10:51 AM
Charter Member#1300
Shane, I have access to a impact screwdriver if you want to borrow it. Todd
Stray Cat is offline
Old 05-24-2004 | 11:19 AM
Panther's Avatar
Frank's Marine Service
Whenever I had a problem with this I quickly hit it with the torch for about 10 seconds. It always works.
Panther is offline
Old 05-24-2004 | 11:59 AM
WILDTHING TAZ's Avatar
B-MAX REPAIR
When You Get It Out I Make A Drain Plug With A Hex On It,and A Magnet 3 Times Stronger. Ron Bender 216-390-1330
WILDTHING TAZ is offline
Old 05-24-2004 | 04:39 PM
Sears is probably the best place to get an impact driver look on craftsman.com and do a search for item #47641 and you can see a pic.
gusman is offline
East Coast B
7
03-24-2007 11:06 AM
vandeano
20
11-02-2006 07:18 PM
ga1990
7
05-17-2005 01:50 PM
Hot Boat
2
01-14-2003 07:57 AM
envision
3
12-28-2002 05:47 PM
