Dirty drive oil, what does it mean?? >
Old 05-24-2004 | 06:12 PM
Default Dirty drive oil, what does it mean??
1990 Bravo 1s. 1 is fine, the other is very dirty. When I drained them I drained through a paint strainer. Neither drive had any pieces, nor anything on the plug magnets except some dust.
What would cause the dirty oil? I am pushing about 650hp in each motor. I have drive showers.
If a rebuild is needed what is the best way to go?
Pure Energy is offline
Old 05-25-2004 | 05:56 AM
Default Re: Dirty drive oil, what does it mean??
Anyone??
Old 05-25-2004 | 08:11 AM
mcollinstn's Avatar
gotta be more specific than "dirty".
color?
sparkly suspension?
caramel streaks?
give us something to go on here.
mcollinstn is offline
Old 05-25-2004 | 10:23 AM
WILDTHING TAZ's Avatar
B-MAX REPAIR
Same Reason Your Car Oil Gets Dirty. Change It
WILDTHING TAZ is offline
Old 05-25-2004 | 10:50 AM
stecz20's Avatar
how often do you change the drive oil????
stecz20 is offline
Old 05-25-2004 | 11:04 AM
MnFastBoat's Avatar
Charter Member#157
every season or 50 hours
is it dirty as in dark?
or diry as in MILKY?
is it hte port side or starboard?
is the one that is running counter rotation? I heard counter roating is harder on parts. Maybe its the cause?
just a thought
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 05-25-2004 | 07:20 PM
stecz20's Avatar
i was asking pure energy!!!!! but thanks mnfastboat
stecz20 is offline
Old 05-25-2004 | 08:39 PM
Dirty as in black, with slight sparkly suspension. Oil is changed about 50 hrs.
Old 05-25-2004 | 11:13 PM
Grease
For $12, get it analyzed. www.analaboratories.com. No affiliation, just happy customer. Other places are http://oilguard.com/oil_analysis_prog.php, or www.blackstone-labs.com.
Old 05-26-2004 | 12:01 AM
RedDog382's Avatar
Sounds like it might be clutch getting ready to let go. I had similar finding in one drive only, but I had big time metal shavings in mine. Found a twisted prop shaft and vertical shaft in the lower. Have replaced upper and lower with Max Machine Worx, but have not disassembled the spent upper yet to see exactly what the problem was (besides the 950 H.P. and heavy throttle hand of the previous owner!).
RedDog382 is offline
Canada Jeff
Drives and Lower Units
10
07-19-2007 02:38 PM
jeff32
06-28-2006 08:48 AM
splashandburn
3
08-30-2004 07:39 PM
Velocity Tom
07-16-2003 10:13 AM
HyperBaja
04-20-2003 05:39 PM
