Speedo help needed. >
Speedo help needed.
Speedo help needed.
Old 06-11-2004 | 11:25 PM
buck183's Avatar
Default Re: Speedo help needed.
LOL. I'll bite, how do you know?
I don't think I put more than 50 psi to her. I was concerned about the very thing I think you're going to tell me about.
Buck
buck183 is offline
Old 06-12-2004 | 06:29 AM
Be careful not to break the drill bit off in the pickup tube. It is a real PITA to get out then.
BadDog is offline
Old 06-12-2004 | 07:59 AM
Mine got packed with crap a couple of times last year. I took a piece of twisted picture hanging wire, about 1/16 inch stuff, and used it like a roto-router at the drive end. Then set the compressor at 25 lbs. and blew through the hose from the speedo side. Worked well.
Kidnova is offline
Old 06-13-2004 | 02:59 PM
mcollinstn's Avatar
I got a box of speedos with blown out brass bourdon tubes in them.
One in particular, a Teleflex 75mph unit, reads 30 mph at rest and wraps all the way around to the "peg" at zero at around 66 or so. Drips water like a mother.
Sure does impress your friends, though.. I'll rent it out for $5/month.
mcollinstn is offline
Old 06-13-2004 | 05:13 PM
buck183's Avatar
Seems reasonable enough. I'll keep that in mind.
Buck
buck183 is offline
Old 06-14-2004 | 01:05 AM
Is there also another design of pickup for the Bravo? Mine is on the forward side of the drive a small plastic piece is inserted into the the platform of the drive then the tubing runs from there to the speedo. It does not have a hole in the drive for the pickup. The drive is a 2001 Bravo 1.36. Thanks
Brian
tmthunder is offline
THEKID29FEVER
Wanted
3
06-18-2008 09:14 AM
Zoom3
Baja
0
12-09-2004 12:09 PM
barron
Cigarette
13
12-07-2003 10:49 PM
88 MACH 1
4
03-07-2003 01:31 AM
